Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Archicad C++ API
Link in gdl script
Vladislav V
Hello) Maybe you know how I can automatically insert a value into a script parameter from an Excel or txt file. For example, I have an area parameter in the script, and I need this value to be taken automatically from an Excel or txt file.
Is there any command in the script to do this?
I will be grateful for the answer).
5 REPLIES 5
runxel
Legend
You can use the GDL Text Add-on to read in arbitrary data.
But bear in mind that the type of the variable will be auto casted. So if it looks like a number it will be treated as one. This might lead to problems with e.g. room lists.
Lucas Becker | AC 27 on Mac | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Thank you!
This is a GDL TEXT I/O extension need to download?
Have you read the link?
In short: No. It's named "Add-on" since you could actually write you own extensions in C++ which would be callable from GDL. But this is one of the default OOTB ones (:
Sorry for the inattention.
