Localization strings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-02-14
12:16 AM
‎2023-08-03
10:29 AM
Doreena Deng
I can`t get over following problem:
I have a GRC file with expressions to localize, but I cant make resource compiler to handle them. I tried to modify the compileGRCs.pl file, but its always the same: as soon as it finds a special character, it reports an error. I studied the documentation for several hours and there is described always only a way to sort the files themselves or make references to the strings, but never how to change the encoding.
I found a function called CHGetUserCharCode / CHSetDefaultCharCode but either I`m using it wrong or its not working..
So - where should the localized sentences be? I believe it`s the project_name.grc file under 'STR#' commands? I can now track them via ACAPI_Resource_GetLocStr (without the special characters of course)..
I`m working on macbook with Xcode 3.2.4 and DevKit 14.
Thanks,
Santi
- Labels:
Add-On (C++)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-02-14 11:13 PM
santi wrote:Is the resource compiler crashing or failing to produce the required output? If so, can you post the perl script you are using to drive the compiler?
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-02-16 11:10 PM
#include "Dim_Round.grc.ro"in the Dim_Round.r file
and generates an output as:
Converting resource files: Dim_RoundFix.grc Dim_Round.grc Cannot get length of string, the string was ok until: (now the whole grc file until the special character is present, ends before it - it does not display the special character) The unmappable charater is: \u0161 Write_Error: GeneralError: Memory allocation error done.the perl script is as I found it in examples:
#! /usr/bin/perl -w use FindBin ; use File::Spec::Functions; use File::Copy; use Cwd; #----------------------------------------------------------------------- # Executes one GRC conversion command #----------------------------------------------------------------------- sub DoGRC ($$$$$) { my ($tool, $sourceDir, $inputFile, $destinationDir, $outputFile) = @_ ; system ("mkdir -p \"" . $destinationDir . "\"") ; # print $tool . " -m r -u 1 -q utf8 0 -T M -i \"" . catfile ($sourceDir, $inputFile) . "\" -j .roo -p \"" . catfile ($sourceDir, "Images") . "\" -o \"" . catfile ($destinationDir, $outputFile) . "\"\n" ; print "\t$inputFile\n"; system ($tool . " -m r -u 1 -q utf8 0 -T M -i \"" . catfile ($sourceDir, $inputFile) . "\" -j .roo -p \"" . catfile ($sourceDir, "Images") . "\" -o \"" . catfile ($destinationDir, $outputFile) . "\""); } #----------------------------------------------------------------------- # Convert GRC #----------------------------------------------------------------------- print "Converting resource files:\n"; my $devKitPath = catfile ($FindBin::Bin, updir (), updir (), updir ()); my $makeResConvTool = "\"" . catfile (Cwd::realpath ($devKitPath), "Support", "Tools", "OSX", "ResConv") . "\""; my $examplePath = Cwd::realpath (catfile ($FindBin::Bin, updir ())); my $resTarget = catfile ($ENV{TARGET_BUILD_DIR}, $ENV{UNLOCALIZED_RESOURCES_FOLDER_PATH}); my $roFolder = catfile ($examplePath, "RO"); DoGRC ( $makeResConvTool, catfile ($examplePath, "RFIX"), "Dim_RoundFix.grc", $roFolder, "Dim_RoundFix.grc.ro" ) ; DoGRC ( $makeResConvTool, catfile ($examplePath, "RINT"), "Dim_Round.grc", $roFolder, "Dim_Round.grc.ro" ) ; opendir (DIR, $roFolder); @files = readdir (DIR); closedir (DIR); foreach $file (@files) { copy (catfile ($roFolder, $file), $resTarget) if ($file =~ /.*\.tif$/); } print "done.\n";I thought that problem would be the coding, but documentation gives me no other choise than present
-q utf8 0Thanks a lot
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-02-17 11:07 AM
santi wrote:I tested this and hit the same problem. It looks like a bug in the GRC compiler - I think we need some input from someone at GS here.
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-02-17 12:54 PM
Ralph wrote:The '-q utf8 0' specifies that the source file's encoding is UTF8. Can you just input that character as a 'normal' character instead of specifying it as a unicode character? Also, the '0' means Mac Roman encoding (old script manager script code), if you use a different language you may have to specify another value here as well.santi wrote:I tested this and hit the same problem. It looks like a bug in the GRC compiler - I think we need some input from someone at GS here.
Best, Akos
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-02-17 07:24 PM
-q utf8 utf8and that worked, compiler succeeded and text is readable
Where do I find the list of <script_code> encodings in a format for compiler? I mean in a GSCharCode format its a number from 0 to 100 or "CC_Name", but in the perl script its something else. I tried to search the documentation and found nothing..
thanks a lot
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-09 07:13 PM
we made a little progress in API development but we are stuck again on the encoding of GRC Compiler:
grc file on a macintosh platform via the perl script in CompileGRCs.pl:
system ($tool . " -m r -u 1 -q utf8 0 -T M -i \"" . catfile ($sourceDir, $inputFile) . "\" -j .roo -p \"" . catfile ($sourceDir, "Images") . "\" -o \"" . catfile ($destinationDir, $outputFile) . "\"");Now I need to add my counry/region encoding - for Czech Republic it is Eastern Europe on windows 1250 - that works well. But on Mac if I tried:
-q utf8 1250 -q utf8 1252 -q utf8 65001 -q utf8 10029and it just doesnt work.. am I doing something wrong? The file compiles but the characters are wrong. I am testing it on czech version of archicad - AC 15 CZE. Again, on Windows is a little bit different process but it works with
-q utf8 1250Thanks,
Santi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-13 10:37 AM
santi wrote:Hello Santi,
system ($tool . " -m r -u 1 -q utf8 0 -T M -i "" . catfile ($sourceDir, $inputFile) . "" -j .roo -p "" . catfile ($sourceDir, "Images") . "" -o "" . catfile ($destinationDir, $outputFile) . """);Now I need to add my counry/region encoding - for Czech Republic it is Eastern Europe on windows 1250 - that works well. But on Mac if I tried:-q utf8 1250 -q utf8 1252 -q utf8 65001 -q utf8 10029and it just doesnt work.. am I doing something wrong? The file compiles but the characters are wrong. I am testing it on czech version of archicad - AC 15 CZE. Again, on Windows is a little bit different process but it works with-q utf8 1250Thanks,
Santi
This is a bit trickier than that.
On Mac you'll have to use the appropriate CFStringEncoding for your region; for Czech it's 29 == kCFStringEncodingMacCentralEurRoman. You can find all the possible values in /System/Library/Frameworks/CoreFoundation.framework/Headers/CFStringEncodingExt.h).
On Windows - as you have already discovered - you have to pass the code page.
So the correct parameters for Czech would be -q utf8 29.
As part of the general direction towards a full Unicode ArchiCAD, we plan to make changes to this system in one of the next major releases.
Best, Akos
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-16 12:07 PM
Santi
