Archicad C++ API
Multi level popup menu
Miha Nahtigal
Hi everyone.
I have a UC::PopupMenu control on my dialog modal window which opens a custom popup.
Would it be possible to create a multi-level popup with the UC::PopupMenu control mentioned above? 
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
Akos Somorjai
The UC popup menu doesn't support that, sorry.
Akos
Akos Somorjai
Akos
Miklos Vegh
Hi, the UCPopupMenu does not support hierarchical menu elements indeed. You can add a pushbutton with an arrow icon and open a context menu aligned on the button edge. The custom context menu can have a hierarchical struct looking like the attached picture.
