Archicad C++ API
SDK examples won't load
Valerie Becquart
Hi
We have build 2 examples files in the SDK 28.200. Each time we add the generated files to Achicad, we got a message "This add-on cannot be validated" in the add-on manager.
Could you please confirm that if you build the apx via the cmake, it does work in the Archicad 28 technology preview.
Also, a little remark, on the website you mention that the SDK is version 28.300 and on the website the latest SDK available for download is 28.2000.
LChen
Could you check whether you've generated your proper Developer/API Local ID and added in xxxFix.grc file?
HTH.
LChen
Could you load the 2 example .apxs with Archicad28 demo mode?
(run Archicad.exe -DEMO)
HTH.
The error still remains...
LChen
HTH.
