ā2009-04-10
01:57 PM
ā2023-07-13
04:20 PM
Doreena Deng
ā2009-04-15 12:57 PM
The only question: is it possible to make the palette name to appear in the Window > Palettes list, so the user can toggle the palette visibility by clicking the corresponding menu item?Solve this by using MenuCode_Palettes indentifier in ACAPI_Register_Menu(). Oh, silly me :oops:
ā2009-08-25 07:24 PM
static CntlDlgData cntlDlgData; static GS::Guid dialogGUID = GS::Guid( "sDock1" ); static short dialogID = 0;
GSErrCode InitPalette()
GSErrCode err = NoError;
// Inintialize the reference in menu command handler
// and show the palette
if ( dialogID == 0 ) {
dialogGUID.ConvertFromString( "sDock1" );
GSResModule actResModule = ACAPI_UseOwnResModule();
dialogID = DGCreateDockablePalette( 32400, CntlDlgCallBack, (long)(void*)&cntlDlgData, dialogGUID );
ACAPI_ResetResModule( actResModule );
DGBeginProcessEvents( dialogID );
DGShowModelessDialog( dialogID );
return err;
After calling the InitPalette() function the panel appears, but it is not dockable. What's the trick?
ā2009-08-25 08:09 PM
ā2009-08-25 08:12 PM
ā2009-08-25 08:26 PM
ā2009-08-25 08:42 PM
// Initialize the reference in menu command handler
dialogGUID.ConvertFromString( "sPanel1" );
return err;
// Callback function for the palette
short DGCALLBACK CntlDlgCallBack( short message, short dialID, short item, long userData, long /*msgData*/ )
CntlDlgData *dlgData = (CntlDlgData*)userData;
switch( message ) {
case DG_MSG_INIT:
if ( ACAPI_RegisterModelessWindow( dialogID, PaletteAPIControlCallBack, API_PalEnabled_FloorPlan + API_PalEnabled_Section + API_PalEnabled_Elevation + API_PalEnabled_InteriorElevation + API_PalEnabled_Detail + API_PalEnabled_Worksheet + API_PalEnabled_3D + API_PalEnabled_Layout) != NoError )
WriteReport( "Test::ACAPI_RegisterModelessWindow failed" );
break;
case DG_MSG_ACTIVATE:
break;
case DG_MSG_UPDATE:
break;
case DG_MSG_CLOSE:
DGDestroyPalette( dialogID );
dialogID = 0;
break;
// Save preferences :
ACAPI_SetPreferences( 1, sizeof(CntlDlgData), &cntlDlgData );
return (0);
GSErrCode __ACENV_CALL PaletteAPIControlCallBack( long referenceID, API_PaletteMessageID messageID )
if (referenceID == dialogID) {
switch (messageID) {
case APIPalMsg_ClosePalette:
DGModelessClose( dialogID );
break;
return NoError;
The docking is not working.
ā2009-08-25 08:52 PM
// Addon.cpp
// --- Addon ------------------------------------------------------------
#include "Palette.h"
GSErrCode __ACENV_CALL Initialize (void)
// Prevent the add-on auto-unloading
ACAPI_KeepInMemory(1);
// Install menu handler
err = ACAPI_Install_MenuHandler (32500, APIMenuCommandProc_32500);
return err;
} /* Initialize */
GSErrCode __ACENV_CALL FreeData (void)
Palette::DeleteInstance();
return NoError;
} /* FreeData */
GSErrCode __ACENV_CALL APIMenuCommandProc_32500 (const API_MenuParams *menuParams)
DBPrintf ("Test::APIMenuCommandProc_32500() %d/%d\n", menuParams->menuItemRef.menuResID, menuParams->menuItemRef.itemIndex);
Palette::ToggleVisibility();
return NoError;
// Palette.h
#pragma once;
// --- Palette ------------------------------------------------------------
class Palette: public DG::Palette
friend class PaletteObserver;
private:
static Palette* m_pPalette;
static PaletteObserver* m_pPaletteObserver;
enum {
CloseButtonId = 1
DG::Button closeButton;
private:
Palette(short resId);
public:
~Palette();
void SelectionChanged(const API_Neig *selElemNeig);
static Palette& GetInstance();
static bool HasInstance();
static void DeleteInstance();
static void ToggleVisibility();
// --- PaletteObserver ------------------------------------------------------------
class PaletteObserver: private DG::PanelObserver,
public DG::ButtonItemObserver,
public DG::CompoundItemObserver
private:
Palette* m_palette;
public:
PaletteObserver (Palette* palette);
~PaletteObserver();
virtual void SourceDestroyed (GS::EventSource* evSource);
virtual void PanelOpened (const DG::PanelOpenEvent& ev);
virtual void PanelCloseRequested (const DG::PanelCloseRequestEvent& ev, bool* accepted);
virtual void PanelClosed (const DG::PanelCloseEvent& ev);
virtual void PanelResized (const DG::PanelResizeEvent& ev);
virtual void ButtonClicked (const DG::ButtonClickEvent& ev);
// Palette.cpp
#if !defined (ACExtension)
#define ACExtension
#endif
#if defined (_MSC_VER)
#if !defined (WINDOWS)
#define WINDOWS
#endif
#endif
#if defined (WINDOWS)
#include "Win32Interface.hpp"
#pragma warning (disable: 4068)
#endif
// ------------------------------ Includes -------------------------------------
#include <stdio.h>
#include <math.h>
#include <string.h>
#if defined (macintosh)
#include <MacTypes.h>
#endif
#include "DG.h"
#include "DGModule.hpp"
#include "ACAPinc.h"
#include "APICommon.h" // also includes GSRoot.hpp
static GS::Guid PaletteGuid ("{9597C98D-95BD-48d9-9999-C2297834806B}");
static GSErrCode __ACENV_CALL ModelessWindowCallBack (long referenceID, API_PaletteMessageID messageID)
if (Palette::HasInstance() && referenceID == Palette::GetInstance().GetId()) {
Palette::GetInstance().SendCloseRequest();
break;
case APIPalMsg_HidePalette_Begin:
break;
case APIPalMsg_HidePalette_End:
break;
case APIPalMsg_DisableItems_Begin:
break;
case APIPalMsg_DisableItems_End:
break;
return NoError;
/*static*/ Palette* Palette::m_pPalette = NULL;
/*static*/ PaletteObserver* Palette::m_pPaletteObserver = NULL;
/*static*/ Palette& Palette::GetInstance()
if (!m_pPalette) {
GSResModule actResModule = ACAPI_UseOwnResModule ();
m_pPalette = new Palette(32420);
ACAPI_ResetResModule (actResModule);
m_pPaletteObserver = new PaletteObserver(m_pPalette);
return *m_pPalette;
/*static*/ bool Palette::HasInstance()
return m_pPalette != NULL;
/*static*/ void Palette::DeleteInstance()
DBASSERT(m_pPalette != NULL);
if (m_pPalette != NULL) {
delete m_pPalette;
m_pPalette = NULL;
if (m_pPaletteObserver != NULL) {
delete m_pPaletteObserver;
/*static*/ void Palette::ToggleVisibility() {
if (m_pPalette != NULL && m_pPalette->IsVisible()) {
m_pPalette->EndEventProcessing();
m_pPalette->Hide();
} else {
Palette::GetInstance().BeginEventProcessing();
m_pPalette->Show();
Palette::Palette(short resId) : DG::Palette(resId, PaletteGuid),
closeButton (GetReference (), CloseButtonId)
ACAPI_RegisterModelessWindow (GetId(), ModelessWindowCallBack,
API_PalEnabled_Layout +
API_PalEnabled_3D
Palette::~Palette ()
ACAPI_UnregisterModelessWindow (GetId());
void Palette::SelectionChanged(const API_Neig *selElemNeig)
if (selElemNeig->neigID != APINeig_None)
DBPrintf("Last selected element: NeigID %d; guid: %s, inIndex: %d\n",
selElemNeig->neigID, (const char *) APIGuid2GSGuid (selElemNeig->guid).ToUniString ().ToCStr (),
selElemNeig->inIndex);
closeButton.Enable();
} else {
DBPrintf("All elements deselected\n");
closeButton.Disable();
PaletteObserver::PaletteObserver (Palette* palette)
: m_palette (palette)
if (DBVERIFY (m_palette != NULL)) {
palette->Attach (*this);
AttachToAllItems (*m_palette);
PaletteObserver::~PaletteObserver ()
if (m_palette != NULL) {
m_palette->Detach (*this);
DetachFromAllItems (*m_palette);
// ... Public methods ..........................................................
void PaletteObserver::SourceDestroyed (GS::EventSource* evSource)
if (evSource == m_palette) {
//MarkAsFinished ();
//notesObserver->FindPaletteDestroyed ();
//palette = NULL;
// ... Dialog notifications ....................................................
void PaletteObserver::PanelOpened (const DG::PanelOpenEvent& /*ev*/)
SetMenuItemMark(32500, 1, true);
/*palette->findEdit.SetText (palette->findData->findText);
palette->replaceEdit.SetText (palette->findData->replaceText);
FindValidate ();
if (palette->findData->findWholeWord)
palette->wholeWordCheck.Check ();
if (palette->findData->findMatchCase)
palette->matchCaseCheck.Check ();
if (palette->findData->findWrap)
palette->wrapCheck.Check ();
if (palette->findData->findUp)
palette->upRadio.Select ();
else
palette->downRadio.Select ();
palette->findEdit.SetFocus ();*/
void PaletteObserver::PanelCloseRequested (const DG::PanelCloseRequestEvent& /*ev*/, bool* /*accepted*/)
m_palette->EndEventProcessing ();
void PaletteObserver::PanelClosed (const DG::PanelCloseEvent& /*ev*/)
SetMenuItemMark(32500, 1, false);
void PaletteObserver::PanelResized (const DG::PanelResizeEvent& ev)
short dh = ev.GetHorizontalChange ();
short dv = ev.GetVerticalChange ();
m_palette->BeginMoveResizeItems();
//dialog->separator.Move (dh, 0);
m_palette->closeButton.Move (dh, dv);
m_palette->EndMoveResizeItems();
// ... Dialog item notifications ...............................................
void PaletteObserver::ButtonClicked (const DG::ButtonClickEvent& ev)
if (ev.GetSource () == &m_palette->closeButton) {
m_palette->SendCloseRequest ();
ā2009-08-25 09:06 PM
static GS::Guid dialogGUID = GS::Guid( "sDock1" );to yours
static GS::Guid dialogGUID( "{9597C98D-95BD-48d9-9999-C2297834806B}" );
ā2009-08-25 09:16 PM
ā2009-08-25 09:19 PM
