2009-04-10
01:57 PM
2023-07-13
04:20 PM
Doreena Deng
2009-04-15 12:57 PM
The only question: is it possible to make the palette name to appear in the Window > Palettes list, so the user can toggle the palette visibility by clicking the corresponding menu item?Solve this by using MenuCode_Palettes indentifier in ACAPI_Register_Menu(). Oh, silly me :oops:
2009-08-25 07:24 PM
static CntlDlgData cntlDlgData; static GS::Guid dialogGUID = GS::Guid( "sDock1" ); static short dialogID = 0;
GSErrCode InitPalette() { GSErrCode err = NoError; // Inintialize the reference in menu command handler // and show the palette if ( dialogID == 0 ) { dialogGUID.ConvertFromString( "sDock1" ); GSResModule actResModule = ACAPI_UseOwnResModule(); dialogID = DGCreateDockablePalette( 32400, CntlDlgCallBack, (long)(void*)&cntlDlgData, dialogGUID ); ACAPI_ResetResModule( actResModule ); } DGBeginProcessEvents( dialogID ); DGShowModelessDialog( dialogID ); return err; }After calling the InitPalette() function the panel appears, but it is not dockable. What's the trick?
2009-08-25 08:09 PM
2009-08-25 08:12 PM
2009-08-25 08:26 PM
2009-08-25 08:42 PM
GSErrCode InitPalette() { GSErrCode err = NoError; // Initialize the reference in menu command handler // and show the palette if ( dialogID == 0 ) { dialogGUID.ConvertFromString( "sPanel1" ); GSResModule actResModule = ACAPI_UseOwnResModule(); dialogID = DGCreateDockablePalette( 32400, CntlDlgCallBack, (long)(void*)&cntlDlgData, dialogGUID ); ACAPI_ResetResModule( actResModule ); } DGBeginProcessEvents( dialogID ); DGShowModelessDialog( dialogID ); return err; } // ----------------------------------------------------------------------------- // Callback function for the palette // ----------------------------------------------------------------------------- short DGCALLBACK CntlDlgCallBack( short message, short dialID, short item, long userData, long /*msgData*/ ) { CntlDlgData *dlgData = (CntlDlgData*)userData; switch( message ) { case DG_MSG_INIT: if ( ACAPI_RegisterModelessWindow( dialogID, PaletteAPIControlCallBack, API_PalEnabled_FloorPlan + API_PalEnabled_Section + API_PalEnabled_Elevation + API_PalEnabled_InteriorElevation + API_PalEnabled_Detail + API_PalEnabled_Worksheet + API_PalEnabled_3D + API_PalEnabled_Layout) != NoError ) WriteReport( "Test::ACAPI_RegisterModelessWindow failed" ); break; case DG_MSG_ACTIVATE: break; case DG_MSG_UPDATE: break; case DG_MSG_CLOSE: DGDestroyPalette( dialogID ); dialogID = 0; break; } // Save preferences : ACAPI_SetPreferences( 1, sizeof(CntlDlgData), &cntlDlgData ); return (0); } GSErrCode __ACENV_CALL PaletteAPIControlCallBack( long referenceID, API_PaletteMessageID messageID ) { if (referenceID == dialogID) { switch (messageID) { case APIPalMsg_ClosePalette: DGModelessClose( dialogID ); break; } } return NoError; }The docking is not working.
2009-08-25 08:52 PM
//////////////////////////////////////////////////////////////////////// // Addon.cpp // --- Addon ------------------------------------------------------------ ... #include "Palette.h" ... GSErrCode __ACENV_CALL Initialize (void) { GSErrCode err = NoError; // Prevent the add-on auto-unloading ACAPI_KeepInMemory(1); // Install menu handler err = ACAPI_Install_MenuHandler (32500, APIMenuCommandProc_32500); ... return err; } /* Initialize */ GSErrCode __ACENV_CALL FreeData (void) { ... Palette::DeleteInstance(); return NoError; } /* FreeData */ GSErrCode __ACENV_CALL APIMenuCommandProc_32500 (const API_MenuParams *menuParams) { DBPrintf ("Test::APIMenuCommandProc_32500() %d/%d\n", menuParams->menuItemRef.menuResID, menuParams->menuItemRef.itemIndex); ACAPI_KeepInMemory(1); Palette::ToggleVisibility(); return NoError; } //////////////////////////////////////////////////////////////////////// // Palette.h #pragma once; // --- Palette ------------------------------------------------------------ class Palette: public DG::Palette { friend class PaletteObserver; private: static Palette* m_pPalette; static PaletteObserver* m_pPaletteObserver; enum { CloseButtonId = 1 }; DG::Button closeButton; private: Palette(short resId); public: ~Palette(); void SelectionChanged(const API_Neig *selElemNeig); static Palette& GetInstance(); static bool HasInstance(); static void DeleteInstance(); static void ToggleVisibility(); }; // --- PaletteObserver ------------------------------------------------------------ class PaletteObserver: private DG::PanelObserver, public DG::ButtonItemObserver, public DG::CompoundItemObserver { private: Palette* m_palette; public: PaletteObserver (Palette* palette); ~PaletteObserver(); virtual void SourceDestroyed (GS::EventSource* evSource); virtual void PanelOpened (const DG::PanelOpenEvent& ev); virtual void PanelCloseRequested (const DG::PanelCloseRequestEvent& ev, bool* accepted); virtual void PanelClosed (const DG::PanelCloseEvent& ev); virtual void PanelResized (const DG::PanelResizeEvent& ev); virtual void ButtonClicked (const DG::ButtonClickEvent& ev); }; //////////////////////////////////////////////////////////////////////// // Palette.cpp #if !defined (ACExtension) #define ACExtension #endif #if defined (_MSC_VER) #if !defined (WINDOWS) #define WINDOWS #endif #endif #if defined (WINDOWS) #include "Win32Interface.hpp" #pragma warning (disable: 4068) #endif // ------------------------------ Includes ------------------------------------- #include <stdio.h> #include <math.h> #include <string.h> #if defined (macintosh) #include <MacTypes.h> #endif #include "DG.h" #include "DGModule.hpp" #include "ACAPinc.h" #include "APICommon.h" // also includes GSRoot.hpp #include "Palette.h" static GS::Guid PaletteGuid ("{9597C98D-95BD-48d9-9999-C2297834806B}"); static GSErrCode __ACENV_CALL ModelessWindowCallBack (long referenceID, API_PaletteMessageID messageID) { if (Palette::HasInstance() && referenceID == Palette::GetInstance().GetId()) { switch (messageID) { case APIPalMsg_ClosePalette: Palette::GetInstance().SendCloseRequest(); break; case APIPalMsg_HidePalette_Begin: break; case APIPalMsg_HidePalette_End: break; case APIPalMsg_DisableItems_Begin: break; case APIPalMsg_DisableItems_End: break; } } return NoError; } // --- Palette ------------------------------------------------------------ /*static*/ Palette* Palette::m_pPalette = NULL; /*static*/ PaletteObserver* Palette::m_pPaletteObserver = NULL; /////////////////////////////////////////// /*static*/ Palette& Palette::GetInstance() { if (!m_pPalette) { GSResModule actResModule = ACAPI_UseOwnResModule (); m_pPalette = new Palette(32420); ACAPI_ResetResModule (actResModule); m_pPaletteObserver = new PaletteObserver(m_pPalette); } return *m_pPalette; } /*static*/ bool Palette::HasInstance() { return m_pPalette != NULL; } /*static*/ void Palette::DeleteInstance() { DBASSERT(m_pPalette != NULL); if (m_pPalette != NULL) { delete m_pPalette; m_pPalette = NULL; } if (m_pPaletteObserver != NULL) { delete m_pPaletteObserver; m_pPaletteObserver = NULL; } } /*static*/ void Palette::ToggleVisibility() { if (m_pPalette != NULL && m_pPalette->IsVisible()) { m_pPalette->EndEventProcessing(); m_pPalette->Hide(); } else { Palette::GetInstance().BeginEventProcessing(); m_pPalette->Show(); } } ////////////////////////////////////////////////////////// Palette::Palette(short resId) : DG::Palette(resId, PaletteGuid), closeButton (GetReference (), CloseButtonId) { ACAPI_RegisterModelessWindow (GetId(), ModelessWindowCallBack, API_PalEnabled_FloorPlan + API_PalEnabled_Section + API_PalEnabled_Detail + API_PalEnabled_Layout + API_PalEnabled_3D ); } Palette::~Palette () { ACAPI_UnregisterModelessWindow (GetId()); } void Palette::SelectionChanged(const API_Neig *selElemNeig) { if (selElemNeig->neigID != APINeig_None) { DBPrintf("Last selected element: NeigID %d; guid: %s, inIndex: %d\n", selElemNeig->neigID, (const char *) APIGuid2GSGuid (selElemNeig->guid).ToUniString ().ToCStr (), selElemNeig->inIndex); closeButton.Enable(); } else { DBPrintf("All elements deselected\n"); closeButton.Disable(); } } // --- PaletteObserver ------------------------------------------------------------ PaletteObserver::PaletteObserver (Palette* palette) : m_palette (palette) { if (DBVERIFY (m_palette != NULL)) { palette->Attach (*this); AttachToAllItems (*m_palette); } } PaletteObserver::~PaletteObserver () { if (m_palette != NULL) { m_palette->Detach (*this); DetachFromAllItems (*m_palette); } } // ... Public methods .......................................................... void PaletteObserver::SourceDestroyed (GS::EventSource* evSource) { if (evSource == m_palette) { //MarkAsFinished (); //notesObserver->FindPaletteDestroyed (); //palette = NULL; } } // ... Dialog notifications .................................................... void PaletteObserver::PanelOpened (const DG::PanelOpenEvent& /*ev*/) { SetMenuItemMark(32500, 1, true); /*palette->findEdit.SetText (palette->findData->findText); palette->replaceEdit.SetText (palette->findData->replaceText); FindValidate (); if (palette->findData->findWholeWord) palette->wholeWordCheck.Check (); if (palette->findData->findMatchCase) palette->matchCaseCheck.Check (); if (palette->findData->findWrap) palette->wrapCheck.Check (); if (palette->findData->findUp) palette->upRadio.Select (); else palette->downRadio.Select (); palette->findEdit.SetFocus ();*/ } void PaletteObserver::PanelCloseRequested (const DG::PanelCloseRequestEvent& /*ev*/, bool* /*accepted*/) { m_palette->EndEventProcessing (); } void PaletteObserver::PanelClosed (const DG::PanelCloseEvent& /*ev*/) { SetMenuItemMark(32500, 1, false); } void PaletteObserver::PanelResized (const DG::PanelResizeEvent& ev) { short dh = ev.GetHorizontalChange (); short dv = ev.GetVerticalChange (); m_palette->BeginMoveResizeItems(); //dialog->separator.Move (dh, 0); m_palette->closeButton.Move (dh, dv); m_palette->EndMoveResizeItems(); } // ... Dialog item notifications ............................................... void PaletteObserver::ButtonClicked (const DG::ButtonClickEvent& ev) { if (ev.GetSource () == &m_palette->closeButton) { m_palette->SendCloseRequest (); } }
2009-08-25 09:06 PM
static GS::Guid dialogGUID = GS::Guid( "sDock1" );to yours
static GS::Guid dialogGUID( "{9597C98D-95BD-48d9-9999-C2297834806B}" );
2009-08-25 09:16 PM
2009-08-25 09:19 PM
