2024 Technology Preview Program
Archicad C++ API
[SOLVED] Dockable palette - is it possible?
Is it possible to create a dockable custom palette like Info Box - in the other words, is it possible to create a window, which can be made floating or docked to some side of the working area?
Thanks.
24 REPLIES 24
The only question: is it possible to make the palette name to appear in the Window > Palettes list, so the user can toggle the palette visibility by clicking the corresponding menu item?
Solve this by using MenuCode_Palettes indentifier in ACAPI_Register_Menu(). Oh, silly me :oops:
Can't make palette dockable. Tried using pure API calls and DG::Palette class.
static CntlDlgData cntlDlgData;
static GS::Guid dialogGUID = GS::Guid( "sDock1" );
static short dialogID = 0;
GSErrCode InitPalette()
	GSErrCode err = NoError;
	// Inintialize the reference in menu command handler
	// and show the palette
	if ( dialogID == 0 ) {
		dialogGUID.ConvertFromString( "sDock1" );
		GSResModule actResModule = ACAPI_UseOwnResModule();
		dialogID = DGCreateDockablePalette( 32400, CntlDlgCallBack, (long)(void*)&cntlDlgData, dialogGUID );
		ACAPI_ResetResModule( actResModule );
	DGBeginProcessEvents( dialogID );
	DGShowModelessDialog( dialogID );
	return err;
After calling the InitPalette() function the panel appears, but it is not dockable. What's the trick?
Did you try to add ACAPI_RegisterModelessWindow()?
No, I didn't.
Just added a call to ACAPI_RegisterModelessWindow() and implemented the APIPaletteControlCallBackProc callback function. The docking is still not working.
Here is what I have now:
	// Initialize the reference in menu command handler
		dialogGUID.ConvertFromString( "sPanel1" );
	return err;
// Callback function for the palette
short DGCALLBACK CntlDlgCallBack( short message, short dialID, short item, long userData, long /*msgData*/ )
	CntlDlgData *dlgData = (CntlDlgData*)userData;
	switch( message ) {
		case DG_MSG_INIT:
			if ( ACAPI_RegisterModelessWindow( dialogID, PaletteAPIControlCallBack, API_PalEnabled_FloorPlan + API_PalEnabled_Section + API_PalEnabled_Elevation + API_PalEnabled_InteriorElevation + API_PalEnabled_Detail + API_PalEnabled_Worksheet + API_PalEnabled_3D + API_PalEnabled_Layout) != NoError )
				WriteReport( "Test::ACAPI_RegisterModelessWindow failed" );
			break;
		case DG_MSG_ACTIVATE:
			break;
		case DG_MSG_UPDATE:
			break;
		case DG_MSG_CLOSE:
			DGDestroyPalette( dialogID );
			dialogID = 0;
			break;
	// Save preferences :
	ACAPI_SetPreferences( 1, sizeof(CntlDlgData), &cntlDlgData );
	return (0);
GSErrCode __ACENV_CALL PaletteAPIControlCallBack( long referenceID, API_PaletteMessageID messageID )
	if (referenceID == dialogID) {
		switch (messageID) {
			case APIPalMsg_ClosePalette:
				DGModelessClose( dialogID );
				break;
	return NoError;
The docking is not working.
Sorry, EzPresso, have no time to test your code.
I am using DG::Palette and DG::PanelObserver. Here is an extracts. Hope it helps..
// Addon.cpp
// --- Addon ------------------------------------------------------------
#include "Palette.h"
GSErrCode __ACENV_CALL	Initialize (void)
	// Prevent the add-on auto-unloading
        ACAPI_KeepInMemory(1);
	// Install menu handler
	err = ACAPI_Install_MenuHandler (32500, APIMenuCommandProc_32500);
	return err;
}		/* Initialize */
GSErrCode __ACENV_CALL	FreeData (void)
	Palette::DeleteInstance();
	return NoError;
}		/* FreeData */
GSErrCode __ACENV_CALL APIMenuCommandProc_32500 (const API_MenuParams *menuParams)
   DBPrintf ("Test::APIMenuCommandProc_32500() %d/%d\n", menuParams->menuItemRef.menuResID, menuParams->menuItemRef.itemIndex);
   Palette::ToggleVisibility();
   return NoError;
// Palette.h
#pragma once;
// --- Palette ------------------------------------------------------------
class Palette: public DG::Palette
  friend class PaletteObserver;
private:
	static Palette* m_pPalette;
  static PaletteObserver* m_pPaletteObserver;
  enum {
     CloseButtonId      = 1
DG::Button closeButton;
private:
  Palette(short resId);
public:
  ~Palette();
  void SelectionChanged(const API_Neig *selElemNeig);
static Palette& GetInstance();
static bool HasInstance();
static void DeleteInstance();
static void ToggleVisibility();
// --- PaletteObserver ------------------------------------------------------------
class PaletteObserver: private DG::PanelObserver,
  public  DG::ButtonItemObserver,
  public  DG::CompoundItemObserver
private:
  Palette*   m_palette;
public:
  PaletteObserver (Palette* palette);
  ~PaletteObserver();
  virtual void   SourceDestroyed (GS::EventSource* evSource);
  virtual void   PanelOpened (const DG::PanelOpenEvent& ev);
  virtual void   PanelCloseRequested (const DG::PanelCloseRequestEvent& ev, bool* accepted);
  virtual void   PanelClosed (const DG::PanelCloseEvent& ev);
  virtual void   PanelResized (const DG::PanelResizeEvent& ev);
  virtual void   ButtonClicked (const DG::ButtonClickEvent& ev);
// Palette.cpp
#if !defined (ACExtension)
#define	ACExtension
#endif
#if defined (_MSC_VER)
	#if !defined (WINDOWS)
		#define WINDOWS
	#endif
#endif
#if defined (WINDOWS)
	#include "Win32Interface.hpp"
	#pragma warning (disable: 4068)
#endif
// ------------------------------ Includes -------------------------------------
#include	<stdio.h>
#include	<math.h>
#include	<string.h>
#if defined (macintosh)
#include	<MacTypes.h>
#endif
#include	"DG.h"
#include	"DGModule.hpp"
#include	"ACAPinc.h"
#include	"APICommon.h"	// also includes GSRoot.hpp
static GS::Guid   PaletteGuid  ("{9597C98D-95BD-48d9-9999-C2297834806B}");
static GSErrCode __ACENV_CALL   ModelessWindowCallBack (long referenceID, API_PaletteMessageID messageID)
	if (Palette::HasInstance() && referenceID == Palette::GetInstance().GetId()) {
       	Palette::GetInstance().SendCloseRequest();
	      break;
      case APIPalMsg_HidePalette_Begin:
	      break;
      case APIPalMsg_HidePalette_End:
	      break;
      case APIPalMsg_DisableItems_Begin:
	      break;
      case APIPalMsg_DisableItems_End:
      	      break;
	return NoError;
/*static*/ Palette* Palette::m_pPalette = NULL;
/*static*/ PaletteObserver* Palette::m_pPaletteObserver = NULL;
/*static*/ Palette& Palette::GetInstance()
	if (!m_pPalette) {
     GSResModule actResModule = ACAPI_UseOwnResModule ();
	   m_pPalette = new Palette(32420);
     ACAPI_ResetResModule (actResModule);
		 m_pPaletteObserver = new PaletteObserver(m_pPalette);
	return *m_pPalette;
/*static*/ bool Palette::HasInstance()
	return m_pPalette != NULL;
/*static*/ void Palette::DeleteInstance()
	DBASSERT(m_pPalette != NULL);
	if (m_pPalette != NULL) {
		delete m_pPalette;
		m_pPalette = NULL;
	if (m_pPaletteObserver != NULL) {
		delete m_pPaletteObserver;
/*static*/ void Palette::ToggleVisibility() {
	if (m_pPalette != NULL && m_pPalette->IsVisible()) {
	   m_pPalette->EndEventProcessing();
	   m_pPalette->Hide();
	} else {
          Palette::GetInstance().BeginEventProcessing();
          m_pPalette->Show();
Palette::Palette(short resId) : DG::Palette(resId, PaletteGuid),
 closeButton (GetReference (), CloseButtonId)
   ACAPI_RegisterModelessWindow (GetId(), ModelessWindowCallBack,
					API_PalEnabled_Layout +
					API_PalEnabled_3D
Palette::~Palette ()
	ACAPI_UnregisterModelessWindow (GetId());
void Palette::SelectionChanged(const API_Neig *selElemNeig)
  if (selElemNeig->neigID != APINeig_None)
      DBPrintf("Last selected element: NeigID %d; guid: %s, inIndex: %d\n",
               selElemNeig->neigID, (const char *) APIGuid2GSGuid (selElemNeig->guid).ToUniString ().ToCStr (),
               selElemNeig->inIndex);
			closeButton.Enable();
	} else {
      DBPrintf("All elements deselected\n");
			closeButton.Disable();
PaletteObserver::PaletteObserver (Palette* palette)
: m_palette (palette)
   if (DBVERIFY (m_palette != NULL)) {
      palette->Attach (*this);
      AttachToAllItems (*m_palette);
PaletteObserver::~PaletteObserver ()
   if (m_palette != NULL) {
      m_palette->Detach (*this);
      DetachFromAllItems (*m_palette);
// ... Public methods ..........................................................
void PaletteObserver::SourceDestroyed (GS::EventSource* evSource)
   if (evSource == m_palette) {
      //MarkAsFinished ();
      //notesObserver->FindPaletteDestroyed ();
      //palette = NULL;
// ... Dialog notifications ....................................................
void PaletteObserver::PanelOpened (const DG::PanelOpenEvent& /*ev*/)
   SetMenuItemMark(32500, 1, true);
   /*palette->findEdit.SetText (palette->findData->findText);
   palette->replaceEdit.SetText (palette->findData->replaceText);
   FindValidate ();
   if (palette->findData->findWholeWord)
      palette->wholeWordCheck.Check ();
   if (palette->findData->findMatchCase)
      palette->matchCaseCheck.Check ();
   if (palette->findData->findWrap)
      palette->wrapCheck.Check ();
   if (palette->findData->findUp)
      palette->upRadio.Select ();
   else
      palette->downRadio.Select ();
   palette->findEdit.SetFocus ();*/
void PaletteObserver::PanelCloseRequested (const DG::PanelCloseRequestEvent& /*ev*/, bool* /*accepted*/)
   m_palette->EndEventProcessing ();
void PaletteObserver::PanelClosed (const DG::PanelCloseEvent& /*ev*/)
   SetMenuItemMark(32500, 1, false);
void PaletteObserver::PanelResized (const DG::PanelResizeEvent& ev)
   short dh = ev.GetHorizontalChange ();
   short dv = ev.GetVerticalChange ();
   m_palette->BeginMoveResizeItems();
   //dialog->separator.Move (dh, 0);
   m_palette->closeButton.Move (dh, dv);
   m_palette->EndMoveResizeItems();
// ... Dialog item notifications ...............................................
void   PaletteObserver::ButtonClicked (const DG::ButtonClickEvent& ev)
   if (ev.GetSource () == &m_palette->closeButton) {
      m_palette->SendCloseRequest ();
Oh, Vladimir, Thank you a lot!
It works now! The Guid was the trick, I just changed
to yours
static GS::Guid dialogGUID( "{9597C98D-95BD-48d9-9999-C2297834806B}" );
Great, EzPresso, glad for you! But, please, dont use my guid, otherwise our addons cannot live together (just joking)
Yes , I have generated another one for myself. Thank you!
