RAFD
cannot open file ACAP_STATD.lib
Does anyone know how to fix this? I tried to correct the path by removing Win but instead of fixing the error I got hundreds more.
23 Replies 23
Akos Somorjai
Please PM me your whole project if possible...
RAFD
Here's the problem from the beginning sir Akos.
I got this errors while building add-on for AC27
to fix this I add the folder link then I got this new errors
I include the ACAPI_MigrationHeader.hpp file then this errors appear
I commend the errors in Migration file that's end in this last error
I got stock here. When I input the correct path, 600 errors more appears
RAFD
By the way sir Akos, It's a working add-on in AC26 and I'm converting it to AC27. Thank you.
Hiromichi Shinkawa
Hi, As I mentioned before, the place of ACAP_STATD.lib has been changed from AC27, please delete WIN\ in the file path of VS project.
HTH
RAFD
Hi LChen, As I mentioned before I already done that and got this 634 errors
I even tried removing the repeated header but nothing change
Hiromichi Shinkawa
Hi, Could you share your whole VS project with us?
RAFD
how about this error?
Hiromichi Shinkawa
I'm not sure, it seems resource build failed.
RAFD
Here's the error in output while building it.
1>The system cannot find the path specified.
1>D:\Visual Studio 2022\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(241,5): error MSB8066: Custom build for 'D:\Users\10025371\TG2T2_Label_Manager\Build\CMakeFiles\c529940aa37135851de05f42f8203d83\AddOnResources.stamp.rule;D:\Users\10025371\TG2T2_Label_Manager\Build\CMakeFiles\36bfbb01dc6dd801ef6d76a10cd99d79\AddOnResources.rule' exited with code 3.
1>Done building project "AddOnResources.vcxproj" -- FAILED.
Hiromichi Shinkawa
Could you build Examples project for AC27 without any error?
