poco2013
Mentor
definition Default Value
Just completed a snippet which changes the Default Value of some Definitions.
I used the function ACAPI_Property_ChangePropertyDefinition, however, that function failed. i seems it has to be wrapped in a undoable callback. ACAPI_callUndoableCommand.
As i look at the other examples in Property_Test none of the other functions need this call back, even to change the definition name.
Wondering why this particular restriction is necessary and is there any work around if I don't need to undo?
Gerry
1 Solution
Ralph Wessel
I took a quick look and it appeared that all the property tests are called from within APIMenuCommandProc_Main, which embeds all these tests in ACAPI_CallUndoableCommand
Ralph Wessel BArch
Central Innovation
Go to post
2 Replies 2
Ralph Wessel
Ralph Wessel BArch
Central Innovation
poco2013
Mentor
Hey Ralph:
Thanks for the heads up. I would of never thought to look there.
Learned something today --- Thanks
Gerry
