Archicad C++ API
how do i get grid name and position in model?
Yeojin Hwang
Hi.
I want to get Grid Name and Position Information.
i use ACAPI_LibraryPart_GetActParameters, but it show only "AC_MarkerText_1"'s default value.  (Example X1)
I would appreciate any help you can give me.
I use Archicad 27 API
            API_GetParamsType getParams;
            BNZeroMemory(&getParams, sizeof(API_GetParamsType));
            err = ACAPI_LibraryPart_GetActParameters(&getParams);
            if (err == NoError) {
                for (Int32 i = 0; i < BMGetHandleSize((GSHandle)getParams.params) / sizeof(API_AddParType); ++i) {
                    const API_AddParType& param = (*getParams.params)[i];
                    if (strcmp(param.name, "AC_MarkerText_1") == 0) {
                        //info.markerText = reinterpret_cast<const char*>(param.value.uStr);
                        info.markerText = GS::UniString(param.value.uStr).ToCStr().Get();
                        DBPrintf("Marker Text: %s\n", info.markerText.c_str());
                        break;
1 REPLY 1
LChen
Hi, I'd suggest you to use ACAPI_Element_GetMemo() to get "AC_MarkerText_1" and "AC_Length" values from memo.params in this case.
I think the position information would be element.object.pos and the end node of
x = element.object.pos.x + (value of "AC_Length") * cos(element.object.angle)
y = element.object.pos.y + (value of "AC_Length") * sin(element.object.angle)
HTH.
