Takahiro Oka
Container Change
Hello
Recently, I started using Archicad and setting up python.
For Setting up development environment I activated Python Palette.
However I couldnt set the specified Python container which is managed by venv to clean default environment.
Can we change that freely?
Thank you.
1 Solution
Takahiro Oka
I solved this problem by running code from VSC Editor with package that have installed from pip.
Thank you.
Go to post
1 Reply 1
Takahiro Oka
Thank you.
