Archicad Python API
About automating tasks in Archicad using the Python API.
Experimental Python add-on is available for Archicad 23
Akos Somorjai
Hi folks,
See the blog post on the developer site: https://archicadapi.Graphisoft.com/experimental-python-add-on-for-archicad23
Good luck!
Akos
86 REPLIES 86
leceta
joel putnam, you can watch some demos by L.Fraguada here
https://discourse.mcneel.com/t/rhino-inside-ue-getting-started/89269/14
BTW thanks for your work with blender. I suspect that if archicad's API would be more open, we would see more tools for ArchiCAD developed by the community.
poco2013
Mentor
I installed the latest Python version - AC23_3000. I noticed that there are a few more functions available that are not listed in the supplied documentation. (Used -- GS Listing.py)
Is there a updated documentation file available or am I not using the latest version?
Gerry
mr_Mikhail
Why are comments closed in the blog?
And understand, it is better to write the questions here?
I was wondering why they decided to leave behind the scenes the definition of functions from the documentation? I would be very interested to try to define them myself.
mr_Mikhail
Tell me please. Is there any function to read the parameters of the GDL object?
mr_Mikhail
I parsed almost all the examples and more or less well understood the work of the API.
The GetElement() function works very strangely. And it is not even in the documentation.
Due to limitations and lack of features, it is very difficult to come up with a more or less working implementation. But something that works as in the examples like as working with a book of layouts can be put to work.
Will there be any news? I had to start diving into the original C++API.
This Python development is in its experimental stage so we will see if and when a permanent implementation will come. I think odds are it will because at the Key Client Conference this summer, GRAPHISOFT talked about their plans to expand the API with Python and JSON. But we will have to wait and see how it pans out.
mr_Mikhail
I need help
You can tell how to control the drawing bounds using the PlaceViewsToLayoutsFromExcel script. Maximum what I was able achieve can be watch in attached file and on video as this works. I don't know how to control the drawing bounds.
I tried to influence API_Box. Can there be that solution in API_Polygon?
Sorry, I am not a Python developer, hopefully someone else will be able to answer you.
mr_Mikhail
Extension doesn't work with python 3.8.
Please check anyone this statement. I have only works with version 3.7.х - 64х
And repeat: Why is not available in the blog comments of the developers?
http://archicadapi.graphisoft.com/blog
You keep writing as if this is a release version piece of software. It is what it is, and is only a toy at this point to play with. As stated on the "Experimental Python Add-On for ARCHICAD 23" page:
"This is strictly an experimental (prototype, "Lab") version.... Enter at your own risk"
When you download and look at the first page (index) of the documentation, you will read:
Python API is an Add-On, which can be run inside ARCHICAD. It implements a python wrapper for the existing C/C++ API. Please note the current state is experimental,
Python 3.7 must be installed to your machine.
This is very clear: you must use Python 3.7 is you want to play.
If the developers have anything to say, they will say it here or in the documentation/developer site. Again, this is an experiment, not a supported product.
