ā2025-07-16 12:46 PM
Actually I have a list of coordinates (in a text/csv/excel file), and I have to position object elements (800 pcs) to the coordinates in the list.
I thought that a python script could do this. I tried with the excel export/import script.
But as far as I can see: with this method I can adjust almost every property, but of the object coordinates.
I need help to solve this issue.
I'm not addicted to the python method, any other solution would be welcomed.
Solved! Go to Solution.
ā2025-07-17
12:55 PM
ā2025-07-18
04:55 PM
You can achieve this without scripting using the SomeStuff add-on and its property-based positioning feature. Here's the workflow:
Create Objects: Place your objects in the model (initial position isn't critical).
Export Properties: Export the objects' properties to Excel.
Set Coordinates in Excel: In the spreadsheet, assign your desired X, Y, (and Z) coordinates to specific custom properties (e.g., Coord_X, Coord_Y, Coord_Z) for each object.
Import Properties: Import the modified Excel file back into Archicad to update the objects' properties.
Automatic Placement: The SomeStuff add-on will automatically position each object based on the coordinate values stored in its properties.
Demo Video:
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
ā2025-07-17 02:54 PM
If I understood you correctly,
SomeStuff add-on can write property values directly into an element's ID field using its Sync_to{ID} command.
I've updated the example file to demonstrate this specific functionality. You can download the latest version to see how Sync_to{ID} works in practice
ā2025-07-16 03:34 PM
To create elements you have two options:
Hope that helps,
Bernd
ā2025-07-16 05:04 PM
Sorry, I'm not familiar with Tapir. I've heard about it, but I thought that it's some kind of rhino/grasshopper "upgrade".
I don't know whether it needs rhino, or works without it?
Do you know any beginner tutorial for tapir_without_rhino?
ā2025-07-17 12:27 AM
That's just a part of it. Don't worry! You don't need Grasshopper or Rhino for that!
Look at the Python examples in the GitHub repo, that should give you a good feel for it.
I'm not aware of any tutorials, tho. Still, with the documentation and the examples you can probably achieve already a lot.
Here, have this very rudimentary example on how to place one object:
import aclib
libpart = "Armchair 04 26"
coor_x = 4.0
coor_y = -3.0
x = 1.0
y = 1.0
z = 1.0
aclib.RunTapirCommand(
'CreateObjects', {
'objectsData': [
'libraryPartName': libpart,
'coordinates': {'x': 0.0 + coor_x, 'y': 0.0 + coor_y, 'z': 0.0 },
'dimensions': {'x': x, 'y': y, 'z': z },
ā2025-07-17 10:30 AM
Thanks for the advices!
But let me ask some questions:
I copied the script, named as a .py script; browsed in archicad tapir palette, run it - but nothing happened.
Is this workaround correct?
Is there a tapir console window somewhere, where you can get messages about the run of the script?
ā2025-07-17 10:43 AM
The archicad report window will provide some info.
Did you use archicad 26? If not, the script won't be able to find the object :
Armchair 04 26
You can also launch the script from visual studio code if you have only one archicad instance open.
ā2025-07-17 11:14 AM - edited ā2025-07-17 11:16 AM
"aclib" was missing!
But copied to the local folder - now it's working.
Thanks a lot!!!
I think I can use this, further on.
ā2025-07-17 12:06 PM
If you give the documentation and some examples to an AI like Claude AI, you'll have a lot of possibilities.
ā2025-07-17
12:55 PM
ā2025-07-18
04:55 PM
Demo Video:
ā2025-07-17 02:39 PM
Dear Dmitry,
wow!!
That's almost perfect!
The only problem I encountered: when I want to set the element ID's, too (with this excel method).
I could set the Coord z parameter property.
I could set in the schedule, export the xlsx, set the desired values. But when I want to import the xlsx back, it shows the new element ID's, but there's no checkbox to update with the new values.
Do you know the solution?
