‎2023-05-31
07:42 AM
‎2024-10-07
01:52 PM
Doreena Deng
I'm reading the bimx api document (API for BIMx Mobile Apps) and I'm interesting in testing the web forms option. Can any one guid me on how to set up the webform and database on our local server.
BR
TorH
‎2023-05-31 02:46 PM
Kind of figured it out. Atleast one way communication BIMx to webform. Might be a webform fault that is the reason for Database will not read back to BIMx
TorH
‎2023-05-31 04:55 PM
Hi, the mentioned demo example allows you to edit the entered remark in the embedded browser popover, and BIMx will show you the updated element information. So it's a bidirectional communication since BIMx UI is extended with a live browser interface. Can you check again that the edited remark is updated in BIMx? Graphisoft has a guideline only for the BIMx extension part with the different use case scenarios; setting up the environment is up to your creativity. Anyway, I hope you find my reply useful.
‎2023-05-31 05:23 PM
Hi, Yes I know... Your demo webform work as it should. But I have created my own webform that also work i one direction. But I need figure out why it doesn't work the other way. database -> BIMx
