2019-04-18
04:22 AM
2023-05-09
04:57 PM
Noemi Balogh
2019-04-27 08:41 AM
2019-04-29 11:59 PM
2019-06-19 11:08 AM
2020-08-25 10:38 PM
2020-08-31 11:26 AM
uisanata wrote:Dear Ernest,
I have the same problem with AC23.
After several successful transfers, it stopped. With the same account, AC 24 works ok. When I started the transfer in AC24 I got a message to resume non-finished uploads from AC23.
Also, the model is heavily corrupted in BimX, with flickering and wrong geometry.
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-09-15 11:09 AM
Thank you very much for your question and I am very sorry about the issue!
From the description, I can see that publishing from AC24 worked well, therefore there should not be any issue with our server. There is one interesting detail: "After several successful transfers, it stopped... when I started the transfer in AC24 I got a message to resume non-finished uploads from AC23."
which suggests that the previous model from AC23 failed to be sent to the transfer site. I am wondering if you can publish the BIMx model locally? Was it successful?
Also, does this issue happen with any files, or with one file only?
Best regards,
Minh
2020-09-15 11:24 AM
Minh Nguyen
GRAPHISOFT
2020-09-15 01:15 PM
mnguyen wrote:
Thank you for the information!
I haven't seen you mentioning about wrong geometry and flickering issue, but it sounds like Far From Origin for me. Please check this article and let me know if this helps. Feel free to ask me if you have any further issues!
Best regards,
Minh
2020-09-16 11:46 AM
uisanata wrote:Hi,
I have sent you a private message with the bimx file.
The model is 150 m from the Origin, I don't think it's the cause of the problem.
Minh Nguyen
GRAPHISOFT
