2013-10-17
05:28 AM
2023-05-09
03:19 PM
Noemi Balogh
2013-10-23 03:02 PM
Daniel wrote:Hi Daniel,
From now on you can save more than just one model in your BIMx file.
2013-10-23 04:18 PM
2013-10-23 04:28 PM
Daniel wrote:But ONLY on your iPad.... All that presentation power and squished onto a napkin....
You can produce the BIMx Hyper-model by creating a publisher set in the Navigator palette, right? Once you have this setted up, you can drag your layouts and views into this publisher set.
As you can set up multiple views for floor plans, you can set up multiple 3D views as well (with different layer combinations, renovation filters, structure display options, etc.). Then you can drag all of these 3D views into your set and publish these into one single BIMx Hyper-model.
In this case you will see all of these views as separate models in the viewer.
These models can be independently updated as well!
One single file, several updatable 3D models for free.
2013-10-23 04:58 PM
2013-10-23 07:54 PM
Daniel wrote:I could be wrong but believe his point was more to do with the inability to view (or use) BIMx Hypermodels on the desktop version (Mac or PC) instead of only just tablets, rather than it was specifically to do with the availability on the Android platform (still valid nonetheless).
Hi Duane,
I see your point.
However, FYI: "BIMx Docs will be released for Android devices in 2014" as it is noted onhttp://www.graphisoft.com/bimx
2013-10-23 08:13 PM
2013-10-25 04:10 PM
2013-10-27 12:14 AM
2013-10-27 02:11 AM
leewoodward wrote:Old BIMx never left. Same as always, nothing lost. It is only if you do the hypermodel thing that it is only viewable on a tablet - iPad now, Android later.
Give me back the old BIMx and I will be able to use it - sort it our GS!
2013-10-29 02:19 PM
