BIMx Publishing Sets
In AC17 we now have the ability to Publish to BIMx files. This looks to be a great feature when combined with BIMx Hyper-docs but I can find any user guides or supporting information on how to set the publisher set up properly.
Anyone seen a guide on this yet?
Matthew Johnson - POWE Architects
AC4.5 --> AC29 & Revit 2016 --> 2024
Asus Zenbook Pro 16x i9-13900H w/ Nvidia RTX 4070 4K dual, Windows 11 64bit + Quest3
I'd rather be sailing.
37 Replies 37
Do you that that via your ipad? Since I have the app already the only option I see is to open the app?
And do you know how to hot fix bimx?
Thanks.
Sally.
Eduardo Rolon
The screenshot was from the iTunes store. For iPad or iPhone go to the App Store and select the share button (see image).
As to the hotfix for the App, I have no idea when it is going to be released so we have to wait until GS finishes it and Apple approves it.
For the Desktop version you have to check if you are updated, go to Window Menu in AC and select "Check for Updates"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
BimX should update when you update AC. Anyway open BimX and check that you have the current build.
AC29 US/INT -> AC08
another Moderator
Thanks Eduardo, your advice is valuable, as always.
Thanks,
Sally.
Link
Agreed!
And just to clarify Eduardo's great idea, the gift option only appears with the paid-for BIMx Docs app, not the original BIMx Viewer.
Thanks Eduardo.
Link.
leewoodward
I am having the same problem with uploading a BIMx hyper model - did anyone get anywhere with this? I have been able to upload previously with no problem, several models but last week I appear to have developed connection problems...
I also have same problem with not beeing able to upload to Graphisoft
Csaba Kezer
Hey All,
Those of you who has a BIMx upload issue please check this guide how to report it to us:
Thanks,
Csaba
Csaba Kézér
VP, Global Customer Support
