We value your input!
BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BIMx Sky
The sky in BIMx is a bit grim. Does anyone have better/alternative skybox (TGA) images they would be willing to share?
12 REPLIES 12
I tried that today, but unfortunately I am not well versed in the texture universe. I could not get the texture (our image) to align correctly. The cylinder would chop my image into 4 pieces and rotate them all 90 degrees. It appeared to me that the cylinder was treating itself as if it were 4 quarter pieces stuck together so my image never wrapped completely around. I use the shell tool to create the cylinder. I created a hollow sphere and tried to map the 360 photo to the inside with even less luck haha
JaredBanks
Mentor
Ah, you're right. That might be a problem. I forget the solution to that issue, but I think there is one. Might be using 2 curved walls and aligning the texture together/at once in 3D.
Jared Banks, AIA
Shoegnome Architects
Erwin Edel
Shell tool has no option to allign texture.
I would recommend using a circular wall, it offers the easiest way to allign textures.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
