BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BIMx and how to export the PDFs from a file?
rob2218
I have this BIMx file. it has connected, coordinated PDF set.
How do export the PDFs "FROM" the BIMx file and create a PDF set only?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
10 REPLIES 10
As far as I know you can't.
The various BIMx viewers are just that - viewers not publishers.
I think the best you can do from BIMx is to go to the options and 'share'.
Then mail or save a screen shot, or directly print what you see on screen.
You will need to export the PDFs from the original Archicad file that created the BIMx file.
James B
If you have the Pro version, it has AirPrint and the Google equivalent, so I guess you could try to print to PDF (like you would do from your computer). I haven't tried though.
James Badcock
Graphisoft Senior Product Manager
rob2218
I have the PRO version and don't see any "Airprint" option so?......
I tried to "Airdrop" it to my IPAD Pro and it fails....file is 85mb....
Any other suggestions?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
bummer....
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
Works for me.
It maybe that your printer isn't "AirPrint" compatible?
Airdropping PDF's from iPad to desktop works as well,
but you can only drop one PDF at a time (AFAIK).
Marc Corney, Architect
Red Canoe Architecture, P. A.
rob2218
I guess I didn't state my question properly.
I have a BIMx file and I'm viewing it on my iphone.
I want to take the sheet contents out of that BIMx file and create/save/export them out to a single PDF set.....it doesn't do that.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
Stress wrote:
Works for me.
Correction:
I can AirPrint single sheets, but airdropping a "sheet" drops the entire BIMx file.
What I did previously was to copy a single sheet from BIMx on my iPad
and paste it into "notes" on my desktop (Apple's Universal Clipboard)
It imported as a .jpg, but I then exported as a PDF. A totally ridiculous workaround and not worth it.
Make a Wish.
It'd be great to have the option to export single & multi-page PDF file directly from BIMx.
rob2218
"Make a Wish.
Amen...let's hope Graphisoft is listening.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Link to the wish (by Marc Corney) where you can vote:
https://archicad-talk.graphisoft.com/viewtopic.php?f=30&t=69603
