BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BIMx rendering
Roopa A
I have imported objects from archieve.3d.net, to the project.
When I do the normal rendering the images are correct. But when I exported to BIMx it is coming pink color, I ticked the check box from Publisher set to render with Generate Global illumination for realistic shading (This will increase rendering time). Still I is coming pink.
I have shared the screenshot, Object looking in AC, Rendered image, BIMx object after GI.
Thank you
Roopa A S
7 REPLIES 7
Hello Roopa A,
Archieve.3d.net is not a BIM platform.
You are able to find some gsm but not lcf files.
LCF are contener files which could include texture but not into a gsm file.
So you must rebuild you surface into archicad with internal engine and maxon engine.
IG is not able to delete texture into your BimX.
Have a nice day,
Christophe Foritneau
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Roopa A
How to do that?
I got lcf file also when downloading. But lcf file cannot be imported to archicad?
Roopa A S
Of course it is possible !
LCF is a Library Contener File.
You should add a library not an object by importing a LCF file.
Christophe - FRANCE
Roopa A
How to add that library?
Roopa A S
Use the Library Manager in Archicad to load extra libraries.
Roopa A
I tried from Library manager, but it is not showing to import the .lcf file.
Roopa A S
Roopa A
I have attached the model the .zip file. I have imported and rendered but it is coming as grey.
How to use it properly
Roopa A S
