We value your input!
BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
Can I open attached file through properties in BIMx?
MagicTurtle
hello.
I found out how to create a Hyperlink by writing a website with Markdown through the link below.
https://community.graphisoft.com/t5/Visualize-articles/Add-hyperlinks-for-all-3D-elements-in-the-Cus...
However, can I open the attachment through the file path stored on the desktop rather than through the website?
From what I've tried, it seems that the hyperlink is not created if it is out of the [UI text] (URL) format.
1 REPLY 1
Tim Ball
If you want someone else to follow a link, the link needs to be a shared resource like Dropbox. You can put the file in Dropbox, create a shared Dropbox link and then paste that into Properties. Using a URL  shortened makes it more user friendly
Tim Ball
AC26, iMac
User since V5
