2018-12-11
04:35 PM
2023-05-09
02:44 PM
Noemi Balogh
| Archicad 4.55 - 27
Solved! Go to Solution.
2021-10-19 04:09 PM
Thank you for the report and I am very sorry about the experience!
Previously, we only receive similar cases coming from Windows. This issue should not happen on macOS. Could you please let us know a bit more about the background system here: macOS version, Archicad version and build number? Furthermore, a screenshot of the issue would be helpful to make sure that we are looking at the right place.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-10-19 04:29 PM - edited 2021-10-19 04:42 PM
Hello and thanks for the quick reply,
I'm currently working with Archicad 23, Build 3003 CHE (Swiss German language).
My computer's specs are:
- MacBook Pro (13-inch, 2018, Four Thunderbolt 3 Ports)
- Processor: 2.3 GHz Quad-Core Intel Core i5
- Memory: 16 GB 2133 MHz LPDDR3
- Graphics: Intel Iris Plus Graphics 655 1536 MB
I'm running with macOS Big Sur version 11.6 . A colleague at my office has the same issue with a new MacBook though, with up-to-date software and OS.
Attached are the screenshots of the Publisher window and File menu, showing the same issue as in the old posts.
Best regards, and thank you for the support!
2021-10-20 11:27 AM
Thank you very much for the screenshot! I found out what might be the problem in this case:
In Switzerland, BIMx, like SwissTools, is only available for KEYMEMBER customers. BIMx and SwissTools are thus accessed via the SSA status. Thus, I suggest contacting your local seller about this problem. They will be able to help you with this process.
Thank you very much for your understanding! Please let me know how it goes!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
