Chris Grantham
Create Graphisoft ID for BIMx Standard
We have client that is unable to have multiple models on their tablet BIMx because they do not have a graphisoft ID.  Ideally we would like for them to have two different versions of a model hence the need for multiple models downloaded to the tablet.  If they were to go and create a graphisoft ID not associated to any company will they get this functionality using BIMx standard?  We don't need a license for each other clients i hope!
16" MacBook Pro M1 Max
Mac OS 26
ArchiCAD 27 Build 6010
3 Replies 3
I believe each of your clients will need to creat a Graphisoft ID if they want to view more than just the one initial model you send them.
https://community.graphisoft.com/t5/BIMx/BIMx-Licensing/ta-p/304184.
Chris Grantham
Thanks, Barry.  I found that page too after some digging.  So if our clients create a GS ID, will that be sufficient to download additional models, or do they need to pay for a license?  I don't need our clients hoovering up our license pool so they can have a couple of models on their iPads.
Mac OS 26
Someone that uses BIMx for there clients will have to answer here.
As far as I know (from reading above), is the client just needs to create a Graphisoft ID which is free to do for anyone.
I am not sure if there are any extra steps where you have to say that a particular GSID can load your BIMx files or if your client simply logging into BIMx with a GSID is sufficient or them to see any files you share with them.
