2022-10-27 04:56 PM - last edited on 2023-05-09 02:51 PM by Noemi Balogh
Hi I am having issues publishing a Bim-x model. It fails every-time. I see similar issues have been experienced by others, but I see no solution to the problem. Can anyone help?
2022-10-28 03:42 AM
There should be a yellow (or red?) warning triangle in the publisher window when it fails.
You can double click it to get information I think.
One thing I would check is that you are not using unusual characters in the file name you are publishing (?~/| etc.).
Keep the name a simple as possible.
2022-10-28 11:14 AM
Hi Barry,
Thanks I checked that message and this is what I get.
As you can see the file name is also quite simple.
2022-10-28 11:38 AM
What do you have in your publisher set.
This will also show me the name you have used.
i.e.
If you create a new publisher set with maybe just a wall or two, will that publish?
Is the path to save the BIMx file correct (i.e. it does exist and you have permission to save there)?
2022-10-28 12:01 PM
Hi Barry,
Please see attached screenshot.
Tried exporting to desktop.
2022-10-28 12:19 PM
Ok, so I tried publishing a single wall, that worked. This means there is probably an element in the 3D that is causing this issue?
I have however down-saved the file to a 25 and published on another workstation without any issues.
2022-10-28 04:00 PM
Settings all look OK.
I would suspect something in the model.
Maybe try turning all layers off and just turn a few on at a time to try and isolate where the problem may be.
