BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
Quantities takeoff from BIMx model
guharlaga
I have received a BIMx model. Is it somehow possible to create material take-offs/schedules from this or do we absolutely need the open the PLN in Archicad?
davdelven
It depends on your whole workflow.
If you need to just check the data without further parsing or dropping, you can use BIMx perfectly. You just need to create a Schedule with all the QTO data you need per each object.
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
Marc H
The BIMx model is published with a data set (an AC Schedule) to support the pop-up element info, but I’m not aware if there is a data export from BIMx.  However, a method I have used with my estimator is to export a schedule of his desired data in spreadsheet (or other preferred) format from the PLN, ideally concurrent with the BIMx package so the versions match.
ā€œThe best thing about the future is that it comes one day at a time.ā€ - Abraham Lincoln
AC28 USA on 16ā€ 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
