2024-01-11 11:20 AM
I have received a BIMx model. Is it somehow possible to create material take-offs/schedules from this or do we absolutely need the open the PLN in Archicad?
2024-01-11 04:04 PM
It depends on your whole workflow.
If you need to just check the data without further parsing or dropping, you can use BIMx perfectly. You just need to create a Schedule with all the QTO data you need per each object.
2024-01-12 11:04 AM - edited 2024-01-12 11:06 AM
The BIMx model is published with a data set (an AC Schedule) to support the pop-up element info, but I’m not aware if there is a data export from BIMx. However, a method I have used with my estimator is to export a schedule of his desired data in spreadsheet (or other preferred) format from the PLN, ideally concurrent with the BIMx package so the versions match.
