2016-09-19
11:00 PM
2023-05-09
02:55 PM
Noemi Balogh
2017-11-22 05:28 AM
2017-11-22 07:33 AM
tilly wrote:I don't think they are saying that you have to convert your version 20 file back to 18 and then save as a BIMx file.
This solution adds at the very least an extra hour to all of our projects and seems to me to be a very clumsy way to achieve a function that used to working perfectly well.
Has anyone found a better workaround for this issue or is it a case of letting our investment of several thousands of dollars slip away into the cold dark depths of technological advancement!
2017-11-22 07:58 AM
Barry wrote:This makes sense. In the previous 'working version' (the version that had all we wanted) in AC19 also only had the option when saving a 'normal' BIMx model. When you saved a BIMx Hypermodel in AC19, the 'Save as' option and GI etc. was not available in BIMx. AC20 and higher can only save Hypermodels.
However it seems you still can not change the global illumination or change other settings and re-save from the BIMx application.
