BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
Where is the BIMx file to upload
It was easy to create the BimX Model
BUT where is it on the harddrive????
I need to transfer the file but where is it.
Eric Milberger, Architect | Master Planner
Did you publish it to the BIMx transfer site?
If so, it will be there.
If not it will be where you told the publisher to save it.
You can choose not to send it to the transfer site and instead save it to your local hard drive or network.
I see now - it acted as if it was doing NOTHING as when you do this it displays nothing.  You can't tell if it is working.  For most programs I would see a dialog popup and show the percentage as it completes the send.  Since it took 15 min or so - it just looked as it was frozen.
This app needs a dialog telling you it is being sent and a percentage bar or text on status.
Then to be friendly a button you can select that takes you to the site to see your model.
