Zermatt [and in 2009: Virtual Building Explorer]
Has anybody heard some news about the zermatt engine? We know it sort of stopped beeing developed any further but any idea if there is still a future for this product?
Thanks Carsten
142 Replies 142
Thomas Holm
Aaron wrote:
Karl,
Do you have a joystick as well?
[and easy on the innuendo, the rest of you]
You mean we're not supposed to comment on Karl's glyphs?
Aaron Bourgoin
I said 'easy' Thomas. nothing more, nothing less.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.1.0 USA
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
Now that the innuendo's taken care of.... I have a SpaceNavigator which, unhappily, does not function with VBE. One of many things to hope for in version 2.0
K
Djordje
I have had mixed results ...
VBE does not work on my work machine, looks like the video card trouble. Crashes ArchiCAD at export, can't run standalone. Only the menu is visible.
Otherwise, agree ... and yes, please, some Client dummies and an AK47!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hi
Can anyone tell why VBE doesn't bring pictures to the VBE model? Textures are fine but where you can choose "use your own picture" like on the carpet 12 and Picture 12 and on tv screen the picture choosen doesn't follow. Anyone?
Hey
and has anybody else problems with the 7 day trial version? I have updated to the latest AC 12 version ( AUS 2420 WIN ) Installed the VBE and opened the licence manager, which proudly activated a 7 day licence for me to use......
Opened AC 12 and wanted to export from the 3D window------message:
Your license is no longer valid
Run VBE license manager to activate your license
After a couple of tries with the licence manager, AC 12 open or closed no difference, I am on this forum.
Any feedback would be great thanks.
Cheers Carsten
ok now they looked me out for 24 hours from the server, because I tried to often! Not really a great way to sale/market a new product.......
Carsten
so after waiting 24 hours I am back in business, at least I thought. It activated the trial licence again, of course with only 6 !! days remaining.
Still no luck in AC12 if I like to export out of the 3D window it tells me again:
I left the licence manager open, still showing activated.
From the silence here I take it none has a clue yet?
Cheers Carsten
David Collins
I downloaded and used the trial program without ever going near the license manager. In fact, I was blissfully unaware of its existance. The VBE opened in trial mode and worked fine.
If all else fails, you might try removing and reloading, then see if it works straight away without opening the license manager.
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080
AC 29.0 (3100 INT FULL)
David Collins
This is one for the GDL gurus. I noticed the same problem.
Thinking there might be an issue with the picture or carpet bitmap, I opened the library part's 3d script, which uses PICTURE in GDL. The bitmap's file name is not in the script and seems to be called internally somehow. Further, I can't find those bitmaps anywhere in the standard ArchiCAD library.
In any case, using a custom image with these objects also fails, so the problem is probably deep inside the PICTURE command.
While these images simple show up white, other types of image files will fail to export, for instance: indexed colored *.BMP files. In this case the VBE export window tells you it failed and won't launch.
David Collins
