2007-11-08 01:07 AM - last edited on 2023-05-09 01:02 PM by Noemi Balogh
2009-03-11 06:34 PM
Carstene wrote:This is not a Graphisoft support channel. You need to contact your reseller and/or local technical support. This is a user-to-user forum, so people only provide solutions to problems that they have encountered. Once you resolve your issue with technical support, I hope you'll post the solution here to benefit others.
From the silence here I take it none has a clue yet?
2009-03-12 06:07 PM
2009-03-12 10:00 PM
2009-03-17 01:03 AM
Karl wrote:KarlCarstene wrote:This is not a Graphisoft support channel. You need to contact your reseller and/or local technical support. This is a user-to-user forum, so people only provide solutions to problems that they have encountered. Once you resolve your issue with technical support, I hope you'll post the solution here to benefit others.
2009-03-20 07:27 PM
2009-03-24 05:32 AM
2009-03-24 07:38 AM
2009-03-24 03:08 PM
2009-03-24 06:19 PM
2009-03-25 07:28 AM
ajg wrote:Adam
Hi all,
Our firm is debating between purchasing Zermatt or VBE... we are unable to make a decision and would love some help.
ZERMATT
*advantage of being able to import 3ds files (useful as we use Max to touch up models, occasionally)
*'looks' better - VBE still looks slightly like archicad in 3d, somewhat (ie: not as slick... more 'cartoony' - not as evocative)
GRAPHISOFT VBE
*direct export from archi - there are 'bounding' elements; can't walk through doors/walls, for eg. In Zermatt, clients may become disorientated by being able to fly through walls, etc.
*might last-longer than zermatt (zermatt's checkered history of completely stopping sales, for a while)
*hidden-line views
*buggy - certain library parts (ie: door handle) are stretched into the distance - hope this makes sense. I can include a screen, if it is important.
If anyone has tried both, I'd appreciate any input. I think we would go-for VBE if we could get it to look the same as Zermatt and if the library parts to behave as expected. Also, having the wall/floor/stair/window boundaries to work.
Thanks for any help.🙂
Adam.
