Roopa A
bimx
How to take model to bimx in Archicad 21
Roopa A S
21 Replies 21
Roopa A
Why AC 18 BIMx is not working in HP laptop. Its a new laptop I installed AC 15 and 18 and AC 15 BIMx is working but not the BIMx 18.
Thank you
Roopa A S
Roopa A
Barry wrote:
Roopa wrote:
BIMx is not working in ArchiCAD 18
Y
I have installed ArchiCAD 18, 19, 20 and 21 and BIMx is working fine in ArchiCAD 19 but not in AC 18, Y?
It is not working - if so what is the problem?
Or you just can't find the 'Publish to BIMx Hyper-model' command in the File menu? - if so do you have the standard work environment set.
Or from the 3D window you can FILE menu > SAVE AS and change to BIMx file type.
Check also the Add-on Manager (Options menu) to make sure the BIMx add-on is installed correctly.
If not I think you have to re-install Archicad as it is part of the installation.
Hai,
No BIMx is not working for 18. What is the issue. This is the 2nd time I am getting this problem. It is a HP new laptop AC 15 BIMx is working fine but not the 18 BIMx. Why?
We tried with the other laptop configuration also like Option 1:
>  HP Pavillion Notebook 15-CB054TX 15.6" Laptop - Price : Rs.70,000
( Core i5 7300HQ : 8GB RAM : 1TB Harddisk : Windows 10 : Nvidia GTX 1050 GPU (2GB) )
Option 2:
>  HP Omen AX248TX 15.6" Laptop - Price : Rs. 73,000
( Core i5 7300 : 8GB RAM : 1TH Harddisk : Windows 10 with MS Office 2016 : Nvidia GTX 1050 GPU (2GB) )
What is the problem. Only for this am getting error.
Can you anybody suggest the solution. Please.
Thank you.
Roopa A S
