Roopa A
bimx
How to take model to bimx in Archicad 21
Roopa A S
21 Replies 21
David Maudlin
Roopa:
It has to be Published. Look for the command Publish BIMx Hyper-model... to walk you through the steps.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Roopa A
BIMx is not working in ArchiCAD 18
Y
I have installed ArchiCAD 18, 19, 20 and 21 and BIMx is working fine in ArchiCAD 19 but not in AC 18, Y?
Roopa A S
Y
It is not working - if so what is the problem?
Or you just can't find the 'Publish to BIMx Hyper-model' command in the File menu? - if so do you have the standard work environment set.
Or from the 3D window you can FILE menu > SAVE AS and change to BIMx file type.
Check also the Add-on Manager (Options menu) to make sure the BIMx add-on is installed correctly.
If not I think you have to re-install Archicad as it is part of the installation.
Roopa A
Barry wrote:
Y
Roopa A S
Roopa A.
Did you have success or not?
Roopa A
Barry wrote:
Roopa A.
No sir
Roopa A S
Roopa A
Roopa wrote:
Barry wrote:
Y
I tired Publish to BIMx Hyper-model command also there when it is publishing its not publishing BIMx.
And even I tried File> Save as command also it is not opening in BIMx. Nothing is showing.
Direct BIMx is also not opening.
I re-installed it still the same problem.
Roopa A S
Erwin Edel
Try saving to desktop, maybe the path you are saving to is giving issues (network location, long path name, etc).
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Roopa A
Roopa A S
