2004-12-07 09:25 PM
2004-12-08 06:10 PM
2004-12-09 04:42 AM
Raphael wrote:I think you are in the right section.
Anyone?Is this posted in the correct section?
2004-12-09 07:17 PM
2004-12-13 03:15 AM
2004-12-14 04:00 PM
2004-12-15 12:33 AM
2004-12-15 05:19 AM
2004-12-20 04:56 AM
2004-12-20 10:55 AM
stefan wrote:If I am not wrong, there used to be a triangulation API sometimes in 6.5 or 7 ... will have to investigate ...
You don't have any control over the internal ArchiCAD triangulation (which comes as no surprise).
2005-02-03 01:02 AM
2005-02-03 01:15 AM
TurboGlider wrote:That is, if you can access the real geometry in the ArchiCAD API... You can query triangulated geometry with the API, but that leaves all the control to the internal ArchiCAD engine.
Maybe some with ArchiCad API and 3ds-file knowledge could write a better export instruction than the standard in AC?
When you export you got more faces than you need (like top of wall, faces between 2 connected wall and gap around windows, all vertex around holes not connected to wall faces) so often you have too optimize the 3d model in 3d Max if you build big worlds and shall make an interactive animation and let your customer walk around like in 3d games.
/Tobias
