‎2015-08-26 12:44 PM
‎2015-08-27 05:27 PM
‎2015-08-27 10:57 PM
‎2015-08-27 11:52 PM
‎2015-08-28 01:16 AM
‎2015-08-28 03:47 AM
strawbale wrote:Good pick-up.
Turns out it was the name of the schedule in the schedule settings menu. I changed the name and it exported.
‎2015-08-28 07:39 PM
If I look at the generated schedule, I can see that the first 3 and last 2 fields are in the column they are supposed to be.
But Column 4 is "Color" (should be Operation Type), Column 5 is Material (Should be Finish - this could also be fine).
So where is the Operation Type column? Is it gone?
‎2015-08-28 10:59 PM
‎2015-08-28 11:03 PM
‎2015-08-30 05:34 AM
strawbale wrote:I can't say for sure now as I try to avoid using them.
do you know of any other situations where choice of character that might pose an issue??
