2D lines / polylines shown in 3D window?
I imported a dwg file with some 2D blocks auto converted in gsm objects and when I switch to 3D all the 2D blocks are showed.
Why normal 2D tools can be shown in 3D window?
2 Replies 2
David Maudlin
This is just the way the translation works when opening dwg files as objects, all the entities are given a 3D component.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
It would be nice to have this feature for archicad 2d tools.
As I understand the workaround it's to save 2d in a dwg file, put it in a block and imported back in AC.
Thank you.
