‎2025-12-05 11:52 AM - edited ‎2025-12-05 12:11 PM
Hi all,
I’m running into an issue when working with a consultant’s 3D DWG in ArchiCAD. Here’s the situation:
I attach the DWG as an Xref, including all layers.
Most layers are visible, but elements drawn in 3D by the consultant do not appear, neither in plan or 3D/section (see screenshot).
If I import the same DWG into Rhino, all elements—including the 3D ones—are visible in both plan and 3D views (see screenshot.
When I attach the DWG as an External Drawing instead of an Xref, the lines from the 3D objects are visible in plan—but I need it as an Xref to maintain layer control.
If I instead use File > Interoperability > Merge, the 3D elements are still missing, and layers are not assigned in the Xref section.
Has anyone encountered this before? Is there a known limitation with ArchiCAD’s handling of 3D DWGs as Xrefs, or is there a workflow that allows me to keep both the 3D geometry and layer control? I've tried playing around with the translator settings but to no good.
I can ask the consultant (using AutoCAD 2026) to save it in a different format, but which one would be the go-to in that case?
Thanks in advance for any tips!
Rhino:
ArchiCAD:
‎2025-12-05 01:57 PM
3D content in a DWG can be brought into the model via GDL. Use "Open Library Part" and selct DWG as the file type to open. This. will convert the 3D elements into a single Archhicad object.
‎2025-12-05 02:03 PM
Is "Open Library Part" different from File > Libraries and Objects > Open Object? Because that option I've already tried and unfortunately it only brought in the 2D elements.
‎2025-12-05 02:43 PM
Yes, Open Object (my bad). Have a look at the settings for the translator you're using. See screenshot. I've selected Binary as the GDL script would be mostly useless.
‎2025-12-08
09:46 AM
‎2025-12-09
09:21 PM
Hm, I used the Open Object dialog, but to no luck. However, I can't find anywhere where to choose a translator in this dialog. What am I missing here? Google is no help, unfortunately.
‎2025-12-08 12:18 PM
it shows up in the dialog where you choose the format DWG. bottom right of the file open dialog? smae place as it does when you use the File open command.
‎2025-12-09 02:14 AM
And in pictures...
‎2025-12-09 09:30 PM
FYI: Whenever you cannot explicitly choose a DWG/DXF Translator, for example, when you place a DWG/DXF with the Drawing tool, Archicad will use the default Translator for Import.
You can go to the DXF-DWG Translation Setup Dialog and check which one it is.
Usually, it is the "02 For editable import" Translator. The little blue left-pointing arrow before its name is that indication for that. In the green arrow column, you can specify if a Translator is used for Export, Import, or Both, and when a Translator is used for Import, you can then use the blue arrow column to specify import Translator should be the default one.
