AC 15 and 3d studio in
Does 3D studio in work on AC15? Because mine doesn't.
7 REPLIES 7
I use it a lot. No problems here.
Strange. Because in my AC15 says that this version of archicad doesn't support 3D studio in.
You have probably installed 3ds-in plugin after applying the hotfix, right?
if so You should apply the hotfix once again on the same AC. 3ds plug installer contains the first version of the plug and is updated with every AC hotfix.
Best Regards,
Piotr
Did you download the add-on? It's not part of the default install.
Thanks! Now everything works just fine
Where can i get this plug-in from? are there separate versions for 32 and 64 bit OS ?
I've been looking on the official website but nothing.
Thank you
Check this post:
http://archicad-talk.graphisoft.com/viewtopic.php?p=199782#199782
