2021-04-16 06:53 PM
2021-04-28 08:25 AM
LaszloNagy wrote:That's interesting since for a structural floor plan you show a slab and the structure that supports it (which is below the slab), where as an architectural floor plan shows the slab and the structure on top of it.
Erwin wrote:
Revit architecture and Revit structure are two separate programs for a reason and from what I understand are not really interchangeable either.
Just a note here: as far as I know, for several years now, there is only a single Revit application, which includes all disciplines. There used to be separate apps for different disciplines, but not anymore.
2021-05-24 03:41 PM
2021-05-24 09:08 PM - edited 2022-07-29 09:09 AM
I am not sure if SAM (structural analytical model) can be exported into most of the prevalent structural design and analysis software, other than RISA or SCIA. However, It would make the existence of SAM more useful if it can straight away be (whether in current excel format or any other) exported to/supported by other structural design tools such as:
Without having the workflow with the above-mentioned tools, the structural capability projection will remain untapped for the most part
2021-11-15 07:56 AM
Exactly.
Limiting the structural workflow only to the applications from the same stable is short sighted. All of the above HAVE to be included, if not in SAM, then in predefined IFC export/import.
Speaking of which... is there a soul that has tweaked the IFC translators for ETABS? or STAAD?
Tekla translators work well for export and import... for example, the attached.
2022-03-12 08:53 PM
Hello!
As structural consultant, I think SAM is one of the most interesting improvements in Archicad. In fact, I decided to work with Archicad when SAM was implemented.
My reason to use Archicad is exactly what @jl_lt suggested: I use Archicad as a consultant because my clients -architects- use Archicad. I want a softer workflow with them, using teamwork or pln instead of receiving dwg or physical ifc, because I think structural consultants cannot expect that architects give a IFC SAM or a SAF, structural consultants must do that.
That said, I think there is an important lack in SAM: it does not work with Truss Maker and Roof Maker objects. Or perhaps Truss Maker and Roof Maker should create beams instead of objects. Anyway, Archicad has not solved that issue, roofs and trusses must be made by hand if we want SAM… it is not operational.
About @Erwin Edel question, Revit has a special kind of views for structural plans, in order to solve the matter about watching structural elements over the cut plan. I still do not know how Archicad manages this, as I have started to use it some days ago 😉
Regards,
Coya
2022-03-15 02:28 AM - edited 2022-03-15 02:29 AM
You may be better off modeling your Trusses and Roof structural elements using multi-segment Columns and Beams. Also, each segment of those Columns/Beams can use Parametric Profiles so almost any kind of geometry can now be modeled with them.
2022-03-16 07:01 PM
Man, this made my day!
