ARCHICAD to AutoCAD Hatch Problem (3D)
Hi all,
When i export to Autocad, hatches work like 3D. How can i fix this? I want it to be displayed as in Archicad.
Podolsky
Ace
It happens because this is how it is in ArchiCAD. Just sanitary elements have white background, that hiding fills below. AutoCAD is not showing this background.
If this hatch is coming from zone - you can safe only zone stamp without the fill (see DWG/DXF conversion settings).
Could you send screen shot, i'm using different language and something is so similar. Thanks.
Podolsky
Ace
Here are settings:
File / Interoperability / DXF-DWG / DXF-DWG Translation Setup...
Try to change saving zones without fill
