2010-09-11 11:16 AM
2010-09-11 11:21 AM
2010-09-11 06:18 PM
mattb wrote:The first part is relatively easy - use one of the User Defined variables in the zone stamp. You can add that field to your schedule. To make it display in the stamp takes a little bit of GDL to modify the stamp - discussed in other threads (look for 'custom zone stamp').
Firstly at an urban level to use zones to show a population number and a density, AC knows the area so can I add a total population parameter to a Zone stamp? Secondly, can AC divide one by the other to give a density??
At a building level, I want to be able to calculate the embodied carbon in the materials. AC knows the volume of each material, I want to add density and carbon per KG to the materials, then get AC to multiply this up.
2010-09-11 07:39 PM
2010-09-11 10:37 PM
2010-09-12 04:45 AM
Master wrote:Actually, GDL can obtain the information on each skin of a composite, and each "component" of a complex profiles element. From there, anything can be calculated - whether for a zone stamp, custom parameter, or a list scheme (via property object).
About the material calculation. Unfortunately it is not possible to request the volume/area of a certain material in a schedule all at once. (I doubt this is possible in a list, is it Karl?)
Because you request information from AC elements (aka not objects), there is no possibility to add GDL code to it.
2010-09-12 09:11 AM
2010-09-12 09:28 AM
2010-09-12 07:30 PM
2010-09-18 08:47 PM
Aaron wrote:And while you are at it, add MADs Zonematic:
Brilliant.
Now, could we somehow combine Master Script's TotalZone, with Yanni Alexakis' LGZone which maps OmniClass "Spaces by Function" Table into a nice package which then grabs a bit of the Cadimage ZoneTools found in their Site+Massing package.
Combine all of that mental horsepower and hard coding and then make it STANDARD functionality in the base package. Then we're getting somewhere.
