Adding schedule values
I have a room schedule that lists the room number, room name, and the area of each room. I'm wondering if there is a way to add a cell at the bottom of the schedule which would give the sum of all of the areas (similar to excel's SUM function). Is this possible? If not any idea of a workaround to achieve the right effect?
1 REPLY 1
Eduardo Rolon
Adding by columns is ok, look for the sigma symbol in the schedule settings. Adding across rows or custom cells is not possible for that you could export to Excel and place a PDF in your layouts
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
