greetings to all of you archicad users (my first post...)
I'd need a help on the following problem: when I export an archicad scene or object using the Cinema Plugin to ac4d file, everything seems to be ok. But when I try to open the file in Cinema 4D, the program shuts itself down instantaneously (no error messages, nothing).
I asked the Maxon technical support for the solution, and after waiting for three months I received the answer that "I should delete the Xfrog 3 plugin from the Cinema 4D Plugins folder". I tried, but no change, it still won't work.
I don't have time to wait for another three months, so I ask you archicad users, if there's someone amongst you who's using the Cinema Plugin, have you had similar problems and if so, how did you resolve them?
I'm using Cinema 4D Studio R9 and ArchiCAD 8.1
Thank for your help
