ArchiCAD v Revit according to Star Wars
Bruce
I've recently realised that many of Yoda's philosophical espousings on the Force etc, can be easily slotted into the discussions of ArchiCAD v Revit
Make the following substitutions for almost any discussion, and you'll be amazed!
Exchange:
"Jedi" with "ArchiCAD user"
"Dark Side" with "Revit"
"The Force" with "BIM"
Example
"A Jedi's [ArchiCAD user's] strength flows from the Force [BIM]. But beware of the dark [Revit] side. Anger...fear...aggression. The dark [Revit] side of the Force [BIM] are they. Easily they flow, quick to join you in a fight. If once you start down the dark [Revit] path, forever will it dominate your destiny, consume you it will, as it did Obi-Wan's apprentice." Luke then says, "Vader. Is the dark [Revit] side stronger?" to which Yoda replies "No...no...no. Quicker, easier, more seductive." And Luke again asks "But how am I to know the good side from the bad?" and Yoda replies "You will know. When you are calm, at peace. Passive. A Jedi [ArchiCAD user] uses the Force [BIM] for knowledge and defense, never for attack."
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
10 REPLIES 10
Djordje
Graphisoft, we DO need the LIKE button!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Rod Jurich
.............. +1
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
haha +1 indeed.
NandoMogollon
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Ya know....
It works the same way the other way around....
Bruce
Only a Sith would say that...
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
LOL...
Been using AC since 7 and Revit since Autodesk took over... I see the strength and weakness on both sides of the force...
For now though, the work is in Revit....not much work on the AC side...Guess instead of a Sith or a Jedi you can call me a mercenary... 😉
Exchange:
You'd also have to rename the droids.
C3PO = C3DO
R2D2 = R3D2
