ArchiForma Problem
I have made an element with ArchiForma(AF) (extrusion), and I have managed to cut it with the cut tool in AF. But every time I try to show it in the 3d window, I get an error message a hundred times, so I have to press Continue equally many times. Really annoying. Below is the error message. Could someone tell me how to avoid this. Is it something I do wrong?
Fabrizio Diodati
Please send me the file and I will check it...
Friendly
Fabrizio
Fabrizio Diodati
rocorona
In the meantime you can avoid the repeated error messages, disabling them in Work Environment / Image and calculation.
You will only get a final error alert at the end of the 3D generation process.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
