Hi, I tried to use the green texture on the tiles, but it cannot show the texture. The same texture is used on the desk (here it is showed right). Dont you know, where is problem? Thank you
Now that i have the file, there's a problem with rendering it because the "CadImage Macros" aren't in the archive. Dang.
But i did open the file and i think the explanation for why the tiles won't accept your new material definition is that you had this box checked - it would prevent material assignment.
I am such an idiot.
I got into this without really studying the title of your post.
Duh.
Do you have the Add-on?
I believe that to edit the materials you'll need the add-on.
But you are already doing so much work with these simple tiles, why not just array some slabs and trim them to fit the room. ArchiTiles shines when importing fancy tile shapes and patterns, not common squares.
When you create a tile by using ArchiTiles you are going to create a "specific-real" tile.
You are defining the tile material, its cost, its productor, etc.
You cannot change the tile material because you are creating a real tile (if you want another color you should build another tile that will have a different code, price, material, etc.).
Fabrizio Diodati Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
