Archicad 19 Goodies
poco2013
Mentor
Just installed Archicad 19 & Goodies Add-ins. I noticed that the Accessories an Interior Wizard are no longer under "Design Extras". Have these been Removed or just Moved??
Gerry
5 REPLIES 5
Aaron Bourgoin
Gerry,
Verify that they were installed by going to the Add-Ons Manager from the Options Menu.
The Mac Installer installed Goodies all at once, but a few were detected in the installer defaults. I had to select them to install all the Goodies.
The Accessories Library installs into the ArchiCAD 19 folder so you can check to see if it's there. If you use this Add-On you can drag its library into the ArchiCAD Library.
Think Like a Spec Writer
AC4.55 through 29 / USA AC29.0.1 USA
Rhino 8.24 Mac
MacOS Tahoe 26.0.1
poco2013
Mentor
Nope -- not listed in the Add-on manager. I used the installer for windows. And I did check all optional add-ons( only two were un checked) Accessories WAS previously checked.
Gerry
Aaron Bourgoin
is the Library in the ArchiCAD 19 folder? Are the Add-Ons in the Add-Ons Folder? If not, try a reinstall with only the missing ones ticked.
if that fails send an e-mail to support@graphisoft.com. could be a bug.
in the meantime, you can download individual installers from this page.
http://www.graphisoft.com/downloads/goodies/AC19/INT.html
The INT ones are the same as the USA ones.
Rhino 8.24 Mac
MacOS Tahoe 26.0.1
hi. i'm new in the archicad so if you be able to help I will be very grateful.
So my problem is the folowing, i have the same problem that poco2013 so i try to do what you say and go to the web site of Graphisoft and install the Goodies, but the libraries appear empty. So what can i do to fix that?
miguelsa,
Make sure you have the add-on library loaded in your Library Manager.
You need to tell Archicad where you have saved the library.
