Just installed Archicad 19 & Goodies Add-ins. I noticed that the Accessories an Interior Wizard are no longer under "Design Extras". Have these been Removed or just Moved??
Verify that they were installed by going to the Add-Ons Manager from the Options Menu.
The Mac Installer installed Goodies all at once, but a few were detected in the installer defaults. I had to select them to install all the Goodies.
The Accessories Library installs into the ArchiCAD 19 folder so you can check to see if it's there. If you use this Add-On you can drag its library into the ArchiCAD Library.
Think Like a Spec Writer AC4.55 through 29 / USA AC28 USA Rhino 8 Mac MacOS Tahoe 26.0
Nope -- not listed in the Add-on manager. I used the installer for windows. And I did check all optional add-ons( only two were un checked) Accessories WAS previously checked.
hi. i'm new in the archicad so if you be able to help I will be very grateful.
So my problem is the folowing, i have the same problem that poco2013 so i try to do what you say and go to the web site of Graphisoft and install the Goodies, but the libraries appear empty. So what can i do to fix that?
miguelsa,
Make sure you have the add-on library loaded in your Library Manager.
You need to tell Archicad where you have saved the library.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
