‎2022-02-17 09:50 PM - edited ‎2022-02-17 09:51 PM
Is there some way to prevent this besides exploding the drawings first? Perhaps I have some setting in the Translator configured wrong ? For example, I joists objects that have been stretched to 20' will all be at the default length in the .dwg. Shower Tray make 3'x5' will revert to 3'x3' in .dwg....
I am using AutoCAD 2022 and Archicad 25 objects for this. anyone else have this issue?
Solved! Go to Solution.
‎2022-02-18 12:29 AM
If it's a library object which is giving you trouble, take a look here:
Solved: Kitchen Layout Object - Goes Bonkers When Saving D... - Graphisoft Community
| Archicad 4.5 - 29
| Archicad 4.5 - 29
