2010-05-07 08:16 PM
2010-05-10 01:04 AM
2010-05-28 03:17 PM
2010-05-31 12:20 PM
2011-01-06 01:39 AM
2011-01-06 10:28 AM
2011-01-08 07:01 PM
2011-01-08 11:19 PM
Da3dalus wrote:I use the Worksheet method and have placed, xRef'd and imported all manner of drawings (DWG, DWF, PDF, etc.) I mostly use placed drawings (even set a hot key for it) as it is the least hassle and works for all file types. The main advantage I find to xRefs is that you can spacebar click (magic wand) the entities in the drawing. With placed drawings it only finds the extents of the drawing.
I'd like to expand the discussion on this: When importing DWG as-built or background drawings on which to start your model, what are the pros and cons of "Place External Drawing" vs. "Attach Xref"?
2011-01-09 04:33 PM
Matthew wrote:You have to teach me how you do that Matthew, because my results are totally different.
As far as performance goes I have created many worksheet references like this with no noticeable performance hit. On some of my larger projects I'm sure I have well over a hundred such worksheets.
2011-01-09 07:39 PM
