Auto Cad 2004 to ARCHICAD 9.0
Long time absent from here. Greetings to all.
Question:
Can't import AutoCad 2004 files into AC 9.0. Is this possible.
Any hint as to what I am doing wrong.
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
3 Replies 3
Eduardo Rolon
It is possible. As to what is wrong, is it not importing or what is happening with it?
OS info will help
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Djordje
Good to read you again!
Yes.
I can answer the same as if you asked me what are you doing now. Send the DWG? What is happening?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Ben Odonnell
Question:
Is it possible that the DWG contains 3D data? If so it will need to be opened as a GDL object.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
